It is currently Mon Jun 23, 2025 2:57 am
PostPosted: Thu Mar 02, 2006 8:37 am
Should I get the 4" X 1.125" or the 7.5 X 2.25? Do I need both? What grit sleeves do you recommend? They have 60,120,150,180,220,and 320.
http://www.grizzly.com/products/H2881
PostPosted: Thu Mar 02, 2006 9:14 am
First name: Nelson
Last Name: Palen
Steve--the little guy (4" x 1.125") would be my recommendation as it is more controllable and gets into tight places such as the cutaway. Then when you find out how nice it works you'll have to have the big guy also.
I would guess 60, 150 and 220 might be a good grit combo.
As mentioned previously in similar posts, a variable speed reversible drill really makes the tool. You don't need a lot of rpm.
Nelson
PostPosted: Thu Mar 02, 2006 9:37 am
Thanks Nelson,
I should have mentioned that I have a nice bench top belt sander and I am looking to use this for sanding the cutaway. Will my Cordless Makita work well with this or will I need to use my A/C drill?
Is this the good size for necks too?
PostPosted: Thu Mar 02, 2006 2:17 pm
I've got the larger one and love it for necks and waists. Cordless VS drills work nicely.
tim...
PostPosted: Fri Mar 03, 2006 12:46 am
i would not recommend trying to do your cutaway on the belt sander. it is far too agressive and very small alignment errors will result in quite a bit of damage.
PostPosted: Fri Mar 03, 2006 2:37 am
I have both. Both are great!
PostPosted: Fri Mar 03, 2006 10:25 am
[QUOTE=Dave-SKG] I have both. Both are great![/QUOTE] Dave. Is there a tool made that ISN'T in your arsenal? Don A38779.7687268518
Users browsing this forum: No registered users and 40 guests
